Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:29
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Waiting for Clarification
Posted by Nate Smith.
Other on team #66, GM Powertrain/Ypsilanti HS/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 1/12/2000 10:16 AM MST
In Reply to: Re: Bad, bad, bad!!! - I agree posted by Raul on 1/12/2000 7:03 AM MST:
: FIRST should allow identical replacement parts to be made anytime. They should, as the update says, allow improvements to be fabbed from the time you check in to the time you ship at the competition.
Because of the two ways this rule could be interpreted(with it meaning either only new systems, or including replacement parts), I e-mailed Eric at FIRST this morninng asking for clarification...
Nate
[IMG] code is Off
Battle-Bots vs. FIRST: good or bad? Kojib Televised Robotics 11 01-03-2004 02:01
college counseling decides to help us... good or bad? AlbertW General Forum 4 16-05-2003 15:14
RCU has bad Analog ports - what now? Icebreakers Programming 13 26-03-2003 07:27
Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? D.J. Fluck Motors 25 05-07-2002 16:40
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
