Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:39
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Ungh
Posted by Adam Anderson.
Student on team #236, Lyme Old Lyme High School, from Lyme Old Lyme High School and Northeast Utilities.
Posted on 1/22/2000 8:54 PM MST
In Reply to: Ungh posted by Dodd Stacy on 1/17/2000 2:02 PM MST:
: : I am not a Mechanical Engineer, and I suppose it depends on whether they grab the bar closer to the center, or towards the ands....but I wonder if the bar could actually hold about 500 pounds? (Anyone know?)
: Four 130 lb robots hanging from the center of the bar would deflect the bar about 1.6 inches and induce a peak stress in the pipe (at the center) of about 53,000 psi. That might be enough to cause a plastic (permanent) deformation of the bar, depending on the grade and quality of the steel in the particular pipe (it's not real highly specified material). The stress comes down quickly for less conservative cases, like with four bots hung 2 by 2, fewer than 4 bots, etc. I think FIRST's position that they'll replace the bar if it bends is probably a reasonable gamble.
They have to if the bend is greater than one inch... they gaurentee the bar will be to specs with in one inch + -
:The peak stress would come down to about 43,000 psi if they used SCH 80 (heavier wall) pipe, which I suspect they would do if one does get bent.
: So I say we all take it as a challenge to BEND THE BAR! It might help if at least one bot in the pile built in the capability to bounce while they're hanging. Right about 2.5 bounces per second (quicker if we can't all pile in the middle) gets everything resonating and the bar is toast.
Ill Bring this up with my coaches, ill see if we can use the pistons to help provide that bounce...
: Dodd
-Adam Anderson-
Team #236
[IMG] code is Off
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
Avg Score CMC General Forum 14 12-03-2002 07:23
