Go to Post Can I help it if I check Chief Delphi before I look at the Team Updates? - Al Skierkiewicz [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:44
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: fastener vs. structure vs. other stuff
Posted by Samuel Lindhorst.
Engineer on team #240, Mach Vee, from Jefferson High School and Visteon.
Posted on 1/22/2000 12:30 AM MST
In Reply to: fastener vs. structure vs. other stuff posted by Ken Patton on 1/21/2000 2:48 PM MST:
: Here's my interpretation:
: If you are using the device to connect two structures together to keep them fixed in contact or very close contact with each other, then its a fastening device and is legal.
: If you are using the device to hold two structures away from each other, then its a structure and not a fastener (so its not a freebie unless it meets some other rule reqt).
: If there is relative motion intended between the two structures, then it is not a fastener (so its not legal unless it meets some other rule reqt).
: my two cents..
: Ken
OK, I asked Eric about this a while back, and he said:
Per the additional hardware list, you are allowed unlimited use of joining plates for the extruded aluminum. Other hardware (slides, hinges, etc.) is
not covered, but you could get a hinge from another source and attach it to a joining plate.
There you have it.
[IMG] code is Off
