Go to Post It's possible to do nearly anything with enough resources and ingenuity. - Madison [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:48
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Pneumatics parts list questions
Posted by nuts4first.
Engineer on team #340, GRR - Greater Rochester Robotics, from Churchville-Chili and Nortel Networks.
Posted on 1/24/2000 7:30 PM MST
Time to help out some rookies.
Is anyone else having any of the following problems with the pneumatics. Can anyone offer any solutions?
1) The 10mm nipple connector (part number KQ2N10-99) calls out to use 10mm tubing on the part list. Howeve, there is no 10 mm tubing in the kit. Is there an alternative way to properly use this part?
2) One of the manifolds is a 10mm input with 6-6mm outputs (part number KM11-06-10-6). Again where is the 10mm tubing?
3) The CD. Was it supposed to come from the Kick-Off? Or, was is supposed to come in the box with the pneumatics? Or, is this CD a rumor? I know that there was one last year, but I hear there is a new one for this year.
4) We are missing 2 10mm nipple connectors (part number KQ2N10-99). Was this left out of everyone's kit? Or just ours.
Thanks,
Team 340
#0047 (ChiefDelphi)
Eureka!
Posted on 1/26/2000 3:49 PM MST
In Reply to: Pneumatics parts list questions posted by nuts4first on 1/24/2000 7:30 PM MST:
Ah....the 10 mm nipple connectors are really '10 mm tubes', these are used to connect to the manifolds.
The correct way to connect it all is:
TANK > 6 mm tube > REGULATOR > 10 mm nipple > MANIFOLD > 10 mm nipple > -MANIFOLD > MANIFOLD PLUG
Good Luck All!!
Team 340
[IMG] code is Off
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Pneumatics Questions RAWdealer59 Pneumatics 1 17-02-2003 12:10
You can pick up pneumatics parts TODAY!!! Thursday archiver 2000 3 23-06-2002 22:43
Is Air on the additional parts list??? Elgin Clock General Forum 12 06-02-2002 21:27
