Go to Post Every game design should be a means to an end. - Mark McLeod [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:54
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
My interpretation...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 1/29/2000 9:37 AM MST
In Reply to: Additional hardware list posted by Russell Pauley on 1/29/2000 7:44 AM MST:
My interpretation (which by the way has proven to be FAR from infallable, so you should really call Eric at FIRST, ext. 107) is that 'extruded fiberglass' refers to composite fiberglass & resin beams. These beams are allowed to be up to 3 inches by 3 inches in cross section (i.e. the cross-section must fit in a 3 inch square).
Where fiberglass is mentioned by itself and the limit is any amount up to 1/8 inch thick, I believe that they are referring to fiberglass mat (or fiberglass cloth) that is intended to be combined with resin to form a composite structure.
We used the 1/8 inch mat last year to form our body. However, there are other uses as well. One of the teams on the National Championship Alliance (Aces High team #176 as I recall) used the fiberglass cloth 'as is' sewing it into a floppy bag (recall that they tried to dye it blue, but fiberglass cloth is not the idea fiber to take a dye -- it was a sort of light, greyish blue).
I suppose if you wanted to make a fiberglass wedding dress for robot that would be allowed also, provided that you used fiberglass cloth that was less than 1/8 inch thick.
By the way, this is not such an outrageous idea.
For on thing, the wedding dress could be a sort of advertisement to suitors that you are ready to walk down the isle if someone would only propose ;-)
A more practical use would be that a wedding gown's train may provide a nice very place for an alliance parterner to 'hang' on ;-) All you'd need to do is avoid entanglement threats and you'd have a solid 10 points for your alliance!
Here comes the bride!!!
Joe J.
[IMG] code is Off
additional hardware + tools archiver 2000 4 24-06-2002 00:20
Helicopter propulsion archiver 2001 20 23-06-2002 22:59
Additional Hardware list confusion archiver 2001 4 23-06-2002 22:29
can we use? Allie Kit & Additional Hardware 5 13-02-2002 15:54
Is Air on the additional parts list??? Elgin Clock General Forum 12 06-02-2002 21:27
