Go to Post The heat gun is not an arm rest. Especially when it is on. - Fuego247 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
GADZOOKS MAN!!!
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 2/2/2000 5:08 AM MST
In Reply to: Re: Hey, Be careful out there... posted by Justin Stiltner on 2/1/2000 11:57 PM MST:
NOT USING THE DRILL MOTORS! ? ! ?
These are easily the most powerful motors in the kit. It is difficult to understand a decision not to use them.
Is there nothing you would prefer to do have the same output force only to move faster?
How about something you would like to do at the same speed but with more force?
Both of these things boil down to wanting more POWER.
If you don't put it in at the motor side, you can't get it out at the output side.
Word from Joe J, 'USE THE DRILL MOTORS!'
Joe J.
[IMG] code is Off
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
