Go to Post Our safety manager isn't allowed to use the power tools, because he used a drill as a pointing device. - daniel_dsouza [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Need Drill Motors, Don't Want F-P Gearboxes
Posted by Dan.
Student on team #10, BSM, from Benilde-St. Margaret's and Banner Engineering.
Posted on 2/2/2000 9:26 PM MST
In Reply to: Re: Need Drill Motors, Don't Want F-P Gearboxes posted by Justin Stiltner on 2/2/2000 8:44 PM MST:
If you use the FP motors for locomotion they WILL burn out and they WILL be slow. It's very likely you'll grind some of those plastic gears as well. You'll be saving your team from a lot of disappointment if you can convince them to use the drill motors.
:-Dan
[IMG] code is Off
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
