Go to Post that Martus character always has a way to take care of them. - Ricky Q. [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:07
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Speed Controller Calibration
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/12/2000 9:23 PM MST
In Reply to: Re: joystick problem posted by Quentin Lewis on 2/12/2000 8:41 PM MST:
: If I recall, there is a calibration button on the motor controllers that allows you to set the middle and end travel of the joystick...that is, without changing your programming at all.
Yep...you can recalibrate the speed controllers to work with the output that the controller is giving them...next to the LED on each speed controller, there's an inset button that you have to use a nail, pen, etc. to press. Hold that button down, then move the joystick controlling that speed controller to its max and min positions, then let it go back to center and release the button on the speed controller. The LED should flash green if the calibration is successful.
[IMG] code is Off
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
The problem with scouting... archiver 2001 10 23-06-2002 23:49
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
