Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 21:56
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Answers (That are sure to raise more questions)
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/21/2000 10:06 PM MST
In Reply to: GM-Powertrain -- #66 posted by Joe Johnson on 2/21/2000 6:12 PM MST:
: 2 wheel drive, drills (?) in the rear, casters in front.
Yes - Drill motors on a no-chain drive
: Ball sucking loader.
Yep - Globe motor controlling 2 PVC rollers wrapped in rubber belting(see new pictures at link below)
: Carries 6 or so balls (guessing)
Would you believe 8 or 9 reliably? Check out the pictures...I didn't believe it at first either!
: Entire ball sucker/basket lifts via nested slides in rear of machine.
That center 'wall' on the basket stays behind, makes it easier to get the balls back out via same method
: Low rider. Entire machine fits below 30 inch bar in starting position.
Yep
: Looks fairly light.
I wish...we were busy making 'speed holes' earlier today, and might have to have a few more put in
: Hangs?
All I can say is see the pictures - 2 van door motors on a common shaft provide a lot of power for lifting, and thanks to the dynamic braking on the V883s, she doesn't like coming back down...
: If you see more or know more, please share your thoughts.
Motor Use:
Drive Train: Drill Motors
Basket Lift: FP motor with pulley/winch system
Infeed/Outfeed Rollers: Globe Motor
'The Hook' Positioning and Extension: Window Motors
'The Hook' Winch/Robot Lift: Van Door Motors
Nate
[IMG] code is Off
Can I use your pictures? (my latest insane project) Katy General Forum 16 20-03-2004 19:54
Pictures, Pictures, and more Pictures Jason Rudolph Robot Showcase 5 21-02-2003 12:06
pictures pictures pictures...and more pictures archiver 2001 0 24-06-2002 01:12
CD forum don't have space for more pictures? Ken Leung General Forum 7 10-04-2002 23:41
pictures, pictures, and woah... tons of pictures Brandon Martus Regional Competitions 12 10-03-2002 17:32
