Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
  #31   Spotlight this post!
Unread 23-06-2002, 21:56
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: WildStang Giving Heartburn... Team #111
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/22/2000 9:52 PM MST
In Reply to: WildStang Giving Heartburn... Team #111 posted by Joe Johnson on 2/22/2000 9:12 PM MST:
Whenever I get online and have ICQ messages waiting for me mentioning a specific machine other than my own, I know there's a problem...and after seeing this picture, I see an easy multi-event winner...if, of course, the drivers are skilled enough to maximize the AWESOME capabilities of that machine...
WildStang, are you taking 'early decision' ally applications yet??? =)
See everybody in Ypsilanti, only 16 days and counting before we get to see the machines again...and I've already got a control program mod for it...
Nate
  #32   Spotlight this post!
#0047 (ChiefDelphi)
Some WildStang Specs
Posted by Raul.
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 2/23/2000 6:46 AM MST
OK, I will tell you some of the honest capabilities.
• Everything you ever want to know about how we handle balls:
Because of the double intake rollers, it can suck in balls while robot is traveling at full speed of about 8 feet/sec (no problem even if balls are rolling towards or away from robot)
Theoretically, it can hold 12 balls. However, to collect 12 balls everything has to go right and it takes very long. There are two ball collection factors that we have to trade off - jamming and time consummed. The more we try to handle the more we have to be careful how they line up.
Although jamming can be an issue, we have a contingency feature built in if balls jam. The overlapping rollers of the extension can be retracted to unjam balls.
It can easily handle 8 balls with a 95% probability of not jamming. And it should take about 25 seconds if they are not too far away. It should take about 15 seconds if they are all lined up. Same when 'catching them from the human player. As the picture shows, the top door acts as a backboard for the human player who can just roll the balls over the top of the player station.
It can handle 10 balls with about 75% probability of not jamming. This should take about 40 seconds
With 12 balls, the odds of them jamming goes to about 50% and it could take a minute or more.
All times are rough and based on minimal interference from other robots.
We obviously will decide how many to pick up as we go. If there is minimal interference (such as may happen when a couple of bots are fighting on the ramp), then we can pick up more.
• Yes, of course we tilt almost flat to go under the limbo bar. All tilt positions are pre-programmed in software.
• We can hang and although we have not actually tried it, it can theoretically lift another robot along with ours. The linear lift / extension is the strongest we have ever had. No multi-section extension lift this year.
• One feature which is not obvious (not shown on in the picture) is that we have a mechanism to pop balls out of the goal. However, this was a last minute addition. So, it has not been tested while on the robot.
Overall, I think we will do well. We did not get anywhere near the practice time we needed because we had to go on a diet (I hope our scale is accurate because we are barely under the minimum).
Raul
  #33   Spotlight this post!
Unread 23-06-2002, 21:57
#0047 (ChiefDelphi)
In awe.
Posted by Andy Baker.
Engineer on team #45, TechnoKats, from Kokomo High School and Delphi Automotive Systems.
Posted on 2/23/2000 8:49 PM MST
In Reply to: Some WildStang Specs posted by Raul on 2/23/2000 6:46 AM MST:
(Gulp)
Ummm... how do you make your robot weight 50 pounds less than what it appears to be???
All I can say is... wow.
Andy B.
  #34   Spotlight this post!
#0047 (ChiefDelphi)
Deja Vu
Posted by Rob Zeuge.
Other on team #121, Rhode Warrior, from Middletown High School and Naval Undersea Warfare Center.
Posted on 2/23/2000 11:54 AM MST
Wow, their robot looks identical in concept to Team 121's Rhode Warrior 2000. Check them out at the link below:
  #35   Spotlight this post!
#0047 (ChiefDelphi)
Boeing ComBBAT (Team #21) Ready to Roll
Posted by Mike Sklar.
Engineer on team #21, ComBBAT , from Astronaut H.S. and Titusville H.S. and Brevard Community College and Boeing Company and NASA-KSC.
Posted on 2/23/2000 9:36 PM MST
In Reply to: Analysis of pictures posted by Joe Johnson on 2/21/2000 5:27 PM MST:
Congratulations to all those who slaved away and continously wonderer
why an earth they were building a pile of scrap parts! The answer of
course is for each of us to define and may really not come for years.
The Boeing NASA 'ComBBAT' Team is ready to role. Here is a quick
picture of the team and the machine just before shipping. More pics to
follow. (Note machine is on a dolly at the bottom, so don't be
confused.)
Check out the pics (which i sent to chiefdelphi's webmaster to put in the picture section)
  #36   Spotlight this post!
#0047 (ChiefDelphi)
Re: Analysis of pictures
Posted by Vince Wilczynski.
Engineer on team Whalers from New London / Montville/ Williams School sponsored by Notheast Utilities / US COast Guard Academy.
Posted on 2/24/2000 8:42 AM MST
Team 124 is ready for review.
The newspaper has some of the details correct, but not all of them.
[IMG] code is Off
Can I use your pictures? (my latest insane project) Katy General Forum 16 20-03-2004 19:54
Pictures, Pictures, and more Pictures Jason Rudolph Robot Showcase 5 21-02-2003 12:06
pictures pictures pictures...and more pictures archiver 2001 0 24-06-2002 01:12
CD forum don't have space for more pictures? Ken Leung General Forum 7 10-04-2002 23:41
pictures, pictures, and woah... tons of pictures Brandon Martus Regional Competitions 12 10-03-2002 17:32
