Go to Post *wonders if omni wheel rollers come in MOE green or have to be dyed* - EricH [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 21:58
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: How is our gear ratio?
Posted by Dodd Stacy.
Engineer on team #95, Lebanon Robotics Team, from Lebanon High School and CRREL/CREARE.
Posted on 2/24/2000 8:56 AM MST
In Reply to: How is our gear ratio? posted by nuts4first on 2/23/2000 1:27 PM MST:
: Is a 15 (on the drill axle) to 18 (on the wheel) gear ratio bad? We are locked in low gear and driving 2-6' wheels with each motor. Our robot weights 130 lbs. I've tried to use some of the speadsheets, but I'm not sure now to read them.
: What does everyone think?
: -Team 340
Nuts,
This is gentle gearing in terms of loading the drill motors and heating them up. Your top speed is probably about 6.3 ft/sec. We have in the past run direct drive (1:1) in LO range to the 6' wheels, 7.6 ft/sec top speed, with no problems.
A suggestion to consider, tho, is to run the drill gearbox in HI range and take a larger, compensating, ratio reduction in the final chain and sprocket stage, netting (nearly) the same overall gearing. This reduces the maximum torque transmitted by the gearbox and any joints in or to the output shaft (like your 15 tooth sprocket), reduces the reaction torque that the drill housing and its mounts need to absorb, and reduces the tension in the chain. And I mean reduces by a factor of 3+.
With all the front/back maneuvering these bots do at max acceleration, it really works the whole system thru a lot of stress reversal cycles. I'll take a factor of 3 load reduction any time, but that's just my opinion. Some folks love tearing down gearboxes, drifting out snapped pins, and fussing with master links in the calm, well-lighted pits. I would also wager that the chain/sprocket reduction stage has a better mechanical efficiency than the plastic planetary stage in the gearbox that is eliminated in this approach.
A 40 T (3/8' pitch) sprocket can fit your 6' wheel (4.78' pitch dia.), and paired with a 10 T drive sprocket and the drill gearbox run in HI, would give you a 6.0 ft/sec top speed vs your present 6.3 ft/sec. A 12 T drive sprocket nets about 7.2 ft/sec. This is working with sprocket availability from SPI - you can probably find a finer mesh of ratios available thru other suppliers, but this is a pretty minor speed range as is. Good luck.
Dodd
[IMG] code is Off
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
