Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:13
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
for those who couldn't translate it.
Posted by Branden Gunn.
Other on team #246, formerly of team #23, and another FIRST-aholic, from John D. O'Byrant High School/Boston Latin Academy/Madison High School/Boston University Academy and Boston Edison/Boston University/Wentworth Institute of Technology/MassPEP.
Posted on 3/6/2000 4:03 PM MST
In Reply to: Re: coded flashes? posted by Thomas A. Frank on 3/2/2000 9:21 AM MST:
: : ._ _. _.. .. ._. . ._ _.. _._. _ _ _ _.. . _ _ _ _ _ _ _ ._._._
: : ._.. :-)
As far as i can translate it
And I read code...
L :-)
Should
the
'L'
be
allowed
to
follow
the
marker
Tom Frank
KA2CDK
#0047 (ChiefDelphi)
Better Idea
Posted by Michael Martus.   [PICTURE: SAME | NEW | HELP]
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
Posted on 3/2/2000 7:02 PM MST
In Reply to: PIT LIGHTS. HERE'S A SOLUTION! posted by Anton Abaya on 3/1/2000 6:02 PM MST:
I have a better idea.
When you go to popular restaurants they give you a pager (vibrator) that tells you your table is ready.
Each team is given one and a desiginated person on each team is in charge. When you are called your pager (vibrator) goes off.
What do you think?
#0047 (ChiefDelphi)
Warning Re. Local Area Pagers
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/2/2000 7:53 PM MST
In Reply to: Better Idea posted by Michael Martus on 3/2/2000 7:02 PM MST:
Last year, we tried using a paging system similar to those that they have at some restaurants...when we tested it in the pit with our machine powered up and running on tether, the radio signal from the transmitter actually caused the drive wheels to start spinning...so you'd have to be careful to get a system that wouldn't interfere...
Nate
#0047 (ChiefDelphi)
RNets were less robust than this year's system (imho)
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 3/2/2000 8:12 PM MST
In Reply to: Warning Re. Local Area Pagers posted by Nate Smith on 3/2/2000 7:53 PM MST:
Has anyone had ANY problems with their radio connection this year?
We have no zero problems.
I am really glad to say goodbye to those RNets.
While they were probably good for what some applications, they were not particularly suited to controlling lots of robots in one location.
We are much happier with the Innovation First system.
Anyway, to address your point, I would be surprised to find that a local page network had any effect on the radios we are using unless they pager's sender unit was using the exact same frequency band AND the sender unit was nearer to the field than the sender units for the game field. Even then, I would not expect anything other than a loss of signal to occur, certainly not an insane robot.
Joe J.
#0047 (ChiefDelphi)
RNets not included...
Posted on 3/3/2000 8:40 AM MST
In Reply to: RNets were less robust than this year's system (imho) posted by Joe Johnson on 3/2/2000 8:12 PM MST:
: Has anyone had ANY problems with their radio connection this year?
: We have no zero problems.
: I am really glad to say goodbye to those RNets.
: While they were probably good for what some applications, they were not particularly suited to controlling lots of robots in one location.
: We are much happier with the Innovation First system.
: Anyway, to address your point, I would be surprised to find that a local page network had any effect on the radios we are using unless they pager's sender unit was using the exact same frequency band AND the sender unit was nearer to the field than the sender units for the game field. Even then, I would not expect anything other than a loss of signal to occur, certainly not an insane robot.
: Joe J.
This occured in the pits at nationals, without the RNets being used...it seemed to effect the robot's electrical system directly(we were running on tether). As soon as we hit the 'Send' button, the drive wheels on our machine started spinning for a couple seconds...
Nate
#0047 (ChiefDelphi)
One Way Convo
Posted by Lora Knepper.
Student on team #69, HYPER (Helping Youth Pursue Engineering & Robotics), from Quincy Public Schools and The Gillette Company.
Posted on 3/3/2000 4:57 PM MST
We got a faulty radio modem in our controls....robot was only having a one way convo. That's our only gripes with it, and over all, I find them to be much superior to the RNets.
Lora
#0047 (ChiefDelphi)
problems problems
Posted by Andrew Rudolph.
Student on team NASA KSC/Michael Krop Senior High School from Michael Krop Senior High School sponsored by NASA Kennedy Space Centre.
Posted on 3/3/2000 6:53 PM MST
At MKHS we had a faulty robot radio. And this happend on saturday before the 'bots were due. But thanks to the generosity of team 59, Syntheon Corporation/ eAc Corporation & Florida International University & Miami Coral Park Senior High School & Carrollton High School ,giving us a spare we were able to practice. Thanks
Andrew Rudolph
[IMG] code is Off
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
Joe - Please answer my question archiver 2000 2 24-06-2002 00:14
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
