Go to Post Omni wheels are cool... but mecanum wheels are COOL!! - dtengineering [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:19
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
a little more-from a top contender
Posted by Andrew Rudolph.
Student on team NASA KSC/Michael Krop Senior High School from Michael Krop Senior High School sponsored by NASA Kennedy Space Centre.
Posted on 3/13/2000 2:50 PM MST
In Reply to: More KSC Info - From a Participant posted by Mike Sklar on 3/13/2000 12:41 PM MST:
We finished in third and was the #3 seed. our bot could only hold 1 ball at a time but pretty much every time we tried to hang we did. we were only 1 point from being top seed. at 32 pts a round average. heat wave and HC-COP were 1 and 2 both with 33 heat wave had a higher total qP's so they got #1 seed. So if you can score the big points and score the big points for them you will do well. we had the 2 highest score of the day 69 Qp's with heat wave and 60 with team 411 the team you talked about getting 2 balls from the HP and still doing well. But both times the deciding factor was the ramp. Both times we hung and our alliance was on the bar or ramp. the best play of the day was when team 186 or 86(not sure) blocked 2 teams from being capeable of getting on the ramp. All by itself winning the round 2 against 1. this shows the importandce of the ramp and bar.
also defence was a key. we picked SPAM as a partner and they didnt put balls in the basket. they had the perfect balance of torque and speed they held back some of the biggest teams around. so if your bot isnt doing what you think it should do change your idea on what it should do .... hang and block.
[IMG] code is Off
Bottom line analysis from KSC archiver 2001 17 24-06-2002 01:41
Qualification results from KSC & alliances (WASH w/ SOAP) archiver 2001 1 24-06-2002 01:38
KSC Report: Day 1 Practice archiver 2000 0 23-06-2002 22:18
Some Notes from KSC Jason Rudolph Regional Competitions 4 13-03-2002 21:18
KSC Results David Kelly Regional Competitions 1 09-03-2002 20:53
