Go to Post Its a good bug too. :) - spadercool [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:23
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Dashboard - Actual use?
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/14/2000 11:48 AM MST
Yet another post from the 'Dashboard Guy'...
Ever since the dashboard port was announced, there has been a LOT of buzz around the teams as to the possibility for advanced feedback. However, after seeing the field at Great Lakes, I only saw two teams actually using a laptop on the field, with at least one more on the way being worked on in the pits. I was just wondering how many people are actually planning to use it? Also, if you are using my decoder, please mention that in your post too. =) Thanks!
Nate
#0047 (ChiefDelphi)
Re: Dashboard - Actual use?
Posted by Justin Ridley.
Engineer on team #221, MI Roboworks, from Michigan Technological University.
Posted on 3/14/2000 1:35 PM MST
In Reply to: Dashboard - Actual use? posted by Nate Smith on 3/14/2000 11:48 AM MST:
We will be using JBoard, a program one of our students made. It's pretty cool.
#0047 (ChiefDelphi)
Posted by Tony K.
Student on team #292, PantherTech, from Western High School and DaimlerChrysler.
Posted on 3/18/2000 4:12 PM MST
I wrote PortSnoop, but since we can't afford a powerful enough laptop, we can't use it. And I don't think we could use it on the field and be in good relations with our coach at the same time .
But I got away with it by using Pbasic's Debug...
Tony
#0047 (ChiefDelphi)
Posted on 3/18/2000 7:35 PM MST
In Reply to: Re: Dashboard - Actual use? posted by Tony K on 3/18/2000 4:12 PM MST:
: I wrote PortSnoop, but since we can't afford a powerful enough laptop, we can't use it. And I don't think we could use it on the field and be in good relations with our coach at the same time .
You sure about that Tony? I've run the demo program with the decoder on machines as low as a 133 Pentium with 16MB RAM...
: But I got away with it by using Pbasic's Debug...
While on the field? How are you pulling that off?
Nate
[IMG] code is Off
miroboworks dashboard program? archiver 2000 3 23-06-2002 23:04
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
Dashboard Protocol Library archiver 2000 9 23-06-2002 22:24
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
