Go to Post You and I have never met, but I am certain that if we went to the same school, we would have been good friends. - Molten [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:33
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
GMCIA Network Expansion! & More Detailed Info
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/28/2000 11:08 AM MST
In Reply to: GMCIA Scouting System - We're on for Florida! posted by Nate Smith on 3/25/2000 10:44 PM MST:
I have just recieved word that two of the teams participating in the GMCIA scouting network at the national competition have secured or are working to secure additional network hubs in order to allow more teams to be connected into the GMCIA network. With the numbers that I have recieved on hub size, this additional hardware will effectively double the number of available connections into the network. However, if the first 17 slots were any indication, these additional spaces(exact number still TBD) will go quickly, so send an e-mail to me at njsmith@online.emich.edu ASAP if you have not yet, and are interested in taking part in this network.
Network format:
RJ-45 Ethernet Hubs(10base-T)
System is running as a web server, using TCP/IP protocol on port 8000.
Necessary Equipment:
Computer with an Ethernet(RJ-45) port and a working web browser.
A 10-25 ft cable to connect your machine to the hub.
Data sharing Method:
Once the list of teams connecting into the GMCIA has been confirmed, a list will be generated, dividing the teams competing at Epcot among the teams participating in the network. There will be some overlap of teams, in order to get a more accurate data set. The participating teams will gather information on their assigned teams, and then return to the Command Center, where this data will be entered into the shared database. The database will be able to process the data on demand, giving you a detailed analysis of a team's strengths and weaknesses.
To sign up:
Send me an e-mail at njsmith@online.emich.edu ASAP with a list of the criteria that your scouts currently use. I will take this list and create a standard GMCIA scouting form, to avoid confusion caused by many different data sets. This form will be in MS Word format, and will be e-mailed to all team contacts once it is completed(hopefully by this weekend.)
Nate Smith
GMCIA Team Coordinator
[IMG] code is Off
Scouting Network Brainstorm Jack FIRST Scouting Network 13 28-05-2003 23:25
Scouting System Name Jack FIRST Scouting Network 10 04-05-2003 21:30
GMCIA 2001 - Who's Interested? archiver 2000 10 23-06-2002 23:50
The problem with scouting... archiver 2001 10 23-06-2002 23:49
GMCIA - It's time once again... archiver 2001 2 23-06-2002 22:35
