Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:01
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Speed Controllers
Posted by Justin Stiltner.
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
Posted on 5/12/2000 8:29 PM MST
In Reply to: Speed Controllers posted by Gary Bonner on 5/10/2000 8:08 PM MST:
Well it sounds like it would but you Must put the jumpers in the coast position because when you remove them the speed controller will default to break mode
also insted of wiring them in series just basically make a y peice of wire in which one speed controller would be attached to each end and the motor attached to the other.
Post if this works!!
Justin Stiltner
Team 388
[IMG] code is Off
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
speed controllers archiver 2000 5 24-06-2002 00:19
Capacitors on speed controllers archiver 1999 7 23-06-2002 22:09
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
