Re: The drills are not FP or Delphi Power Sliding Door Motors...
Posted by Matt Leese.
Student on team #7 from Parkville High School and NASA, Black & Decker, AAI, Raytheon.
Posted on 7/2/2000 2:34 PM MST
In Reply to: Re: The drills are not FP or Delphi Power Sliding Door Motors... posted by Justin Stiltner on 7/1/2000 7:36 PM MST:
Well, obviously using all four drill motors would in no way be required. You could use none for all anyone would care. You'd have to engineer with trade-offs (isn't that more like the real world then?).
Adding a second fuse isn't going to do anything at all -- you have to use a higher amp fuse. They'd need to raise the weight limit if we were to use two batteries (they're at least 1/10th of the robot weight right now and there's no way you're packing a second one on). It'd also be much more of a pain to wire.
Matt Leese
