Go to Post If Teflon-coated pans have a no-stick surface, then how to they get the Teflon to stick to the pans? - dlavery [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:10
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Don't let's get too crazy here...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/18/2000 6:15 PM MST
In Reply to: Re: yes and no... posted by Raul on 10/18/2000 4:02 PM MST:
So it has come to this, has it?
The purpose of the no precision machining rule is to try to make it a somewhat level playing field while at the same time making it a 'kids can do it themselves' type of affair.
I don't want to have to get too technical on this one.
As to whether a precision indexing head or other fixture is allowed in conjuction with a drill press... This one is getting pretty close to the line. I would be much happier if I heard that a team used a laser printer to make a template, some tape to stick it to their raw stock and very careful person armed with a center punch and a hammer to transfer the pattern. In the end, I don't know how I would be able to tell the difference in the result.
As to precision machining a custom fixture to use to make your parts (whether made from legal kit material or not), this seems a bit beyond the line to me.
In any case, are you REALLY SURE you need to go to such trouble?
I hope this helps.
Joe J.
[IMG] code is Off
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
Team list & Events archiver 2000 2 23-06-2002 22:39
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
Suggested list of things to bring to the regionals Andrew Wyatt Technical Discussion 1 06-03-2002 14:41
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
