Go to Post Problem with microprocessors: they do exactly what you tell them to do - KenWittlief [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:20
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: 4x4 software differential
Posted by James.
Coach on team #21, ComBBAT, from Brevard Community College and Boeing.
Posted on 11/5/2000 4:04 PM MST
In Reply to: Re: 4x4 software differential posted by nick reynolds on 11/4/2000 10:14 PM MST:
Correct, three motors, two drills (right and left) and one other motor for steering. The third motor is also connected to the same axis of the joy, X axis, the speed and direction of the drills is connected to the y axis. Forward and back is easy, but not turning left or right at fourth travel of the joy.
: James. You dont say how many motors you are using but assuming your using three ' 2 for driving and 1 for steering ' then it should be fairly easy.
: One motor drives the right side, one the left side. The left wheels are connected by a chain or a thin 'V' belt so they run at the same speed. The right the same.
: If you turn left then the right motors drive faster than the inside ones as the joy stick is moved in that direction, and vice versa. the third motor is reserved to help steer by rotation of the four wheels in unison.
: One of the buttons on the joy stick could be used to operate the third motor for over steering or side ways driving?
: The tricky part is to have the wheels turn while they are being steered at the same time but it can be done simply.
: Soft ware should not be to much of the equation.
: nick 237.
: : I am trying to come up with a single joystick operated 4x4 base that the front wheels are steerable. I have tried tank style single joysitck and doesn't work well. So I need software 'differential.' Both motors going in the same direction, but at different speeds while turning proportional to the radius of the turn. The tighter the turn, the slower(to a point) the inside motor spins. Any thoughts?
: : James Rallo
[IMG] code is Off
SCRRF Design Classes Redhead Jokes Southern California Regional Robotics Forum 0 10-07-2003 17:29
which software Ryan Foley 3D Animation and Competition 5 01-03-2003 23:39
any one get the software yet?! activemx 3D Animation and Competition 17 28-11-2002 19:06
software software software archiver 2001 5 24-06-2002 00:21
Reactor software? Adrian Wong 3D Animation and Competition 4 15-01-2002 16:45
