Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:21
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: 4x4 software differential
Posted by James.
Coach on team #21, ComBBAT, from Brevard Community College and Boeing.
Posted on 11/8/2000 12:45 PM MST
In Reply to: 4x4 software differential posted by James on 11/4/2000 1:27 PM MST:
: I am trying to come up with a single joystick operated 4x4 base that the front wheels are steerable. I have tried tank style single joysitck and doesn't work well. So I need software 'differential.' Both motors going in the same direction, but at different speeds while turning proportional to the radius of the turn. The tighter the turn, the slower(to a point) the inside motor spins. Any thoughts?
: James Rallo
I have figured out a simple little program that does what I needed. Thanks to all. Here it is:
**note: untested in the real world, only tested on computer**
Pwm1 is the right motor
Pwm2 is the left motor
Pwm3 is the steering motor(if using a speed controler)
relay1 is the steering motor (if using a spike)
'---------4x4 differential----------------------------------------------------
If p1_y=127 then notmoving:
adjustrightspeed
If p1_x>138 then adjustright: goto dontadjustright
adjustright
pwm1=(p1_y-(p1_x/19)) min 0 max 254 :goto adjustleftspeed 'adjust the speed of the left wheel
dontadjustright
pwm1=p1_y
adjustleftspeed
If p1_xp1_x then subtract:
If sensor1
[IMG] code is Off
SCRRF Design Classes Redhead Jokes Southern California Regional Robotics Forum 0 10-07-2003 17:29
which software Ryan Foley 3D Animation and Competition 5 01-03-2003 23:39
any one get the software yet?! activemx 3D Animation and Competition 17 28-11-2002 19:06
software software software archiver 2001 5 24-06-2002 00:21
Reactor software? Adrian Wong 3D Animation and Competition 4 15-01-2002 16:45
