Go to Post If it's anything that FIRST's competitive spirit has taught me, its to take the good with the bad. - Mike Schroeder [more]
Unread 08-10-2001, 10:01
Dennis Hughes Dennis Hughes is offline
#0027 (Team Rush)
Dennis Hughes is on a distinguished road
Drill motor gearBox question
Does anyone now the actual stepped gear reduction ratio for the drill motor gearbox? I know the gearbox in high is approx. 20:1 and in low is approx 64:1. I'm looking for the actual gear ratio for each stage,(gearbox has 3 stages), in high gear as well as low?
I figured I would ask the community before I go through the trouble of cracking open a gearbox.
Unread 08-10-2001, 13:18
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Hello Dennis
You might also look through the FIRST handbook. They might list the ratios for the gearbox. I know it lists the speed and torque of the various motors we use from the kit.
Hope this helps.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 08-10-2001, 14:53
ChrisH
Posts: n/a
Dennis,
You might as well just crack one open. The drill motor gearboxes are 3 stage planetary gears. The gear ratio depends on which stages are locked. Though as I recall all of the stages use the same gears.
A good mechanical engineering reference book like the Lindberg PE exam book or "Mechanical Engineering Design" by Shigley will have the formulas for the effective gear ratio if you have the numbers of teeth.
Actually, taking one apart would be a good educational exercise. Putting one back together is even more of one. Last year we had to do this several times to rebuild gearboxes when we broke components. Once you learn how it's not a big deal.
I'd tell you how, but I don't remember off hand and the nearest gearbox I know of is several miles away...
Chris
Unread 10-10-2001, 10:00
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
planetary gear ratios
Dennis,
For each planetary set, the gear ratio can be calculated as follows:
1. the small gear in the middle is the sun gear, the internal gear (the one with the teeth on the inside also called the fixed gear) is called the ring gear.
2. the gear ratio for each stage is calculated as folows:
# of teeth on ring gear
------------------------------ + 1
# of teeth on sun gear
3. Multiply each stage's gear ratio together to get the total ratio. If in high speed, the second stage gear ratio is 1; so only multply the 1st and the 3rd stages.
-Paul
Unread 11-10-2001, 07:11
#0027 (Team Rush)
Thanks Paul !!
If anyone is interested, this is what I calculated:
Planetary gear train stage 1: (motor gear as the sun gear)
Ratio= 4.5:1
Planetary gear train stage 2:
Ratio= 3.2:1
Planetary gear train stage 3:
Ratio= 4.3:1
Looks like it correlates to the published overall gearbox ratio's I've see and used in the past of 64:1 (Low) and 20:1 (High)
Thanks Again
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
