Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 23-06-2002, 23:18
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Impossible? Who knows...Allowed? Nope...
Posted by Nate Smith at 1/20/2001 12:06 PM EST
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
In Reply to: circuit breaker
Posted by Josh on 1/20/2001 9:55 AM EST:
Not a bad idea, but unfortunately, it's not allowed...rule C1:
The Operator Interface, Robot Controller, Servos, Speed Controllers, Relay Modules, Radio Modems, Batteries, Battery Charger, Power Supply, 9 pin cables, CIRCUIT BREAKERS, fuses, and joysticks may not be tampered with, modified, or adjusted in any way...
I know there have been a couple updates that slightly modified this rule, but none of the changes had anything to do with the breaker...sorry..
Nate
[IMG] code is Off
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
120 A circuit breaker tbmantia Electrical 2 05-02-2003 12:30
Pump Problems... archiver 2001 2 23-06-2002 23:58
60 amp Circuit Breaker Info archiver 2001 1 23-06-2002 22:33
Circuit Breakers: Tripping Al Skierkiewicz Electrical 7 10-04-2002 12:40
