Go to Post "Rookie" just means you are new to the game, not that your team isn't as skilled as many already in the competition. - Bill Moore [more]
Unread 23-06-2002, 23:46
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
close enough for govt work...
Posted by control guy at 1/29/2001 10:29 AM EST
Student on team #250 from HVCC.
In Reply to: Re: PBASIC Loop Speed?
Posted by Lloyd Burns on 1/28/2001 4:38 AM EST:
The program loops are roughly 1/40 sec. Although, the time between loops can vary if you lose signal momentarily. Also, depending on your code, a program loop may take longer some times around than other times. Such as if you had many strings of if statements and you're having the program go here, then here, then here, etc., etc. Hope this helps.
[IMG] code is Off
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
The New PBASIC rbayer Programming 10 07-01-2003 21:02
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
