Go to Post Andy Baker can legally touch the Red and Blue Carpet simultaneously. - Taylor [more]
Unread 10-10-2001, 10:00
President, VEX Robotics, Inc.
planetary gear ratios
Dennis,
For each planetary set, the gear ratio can be calculated as follows:
1. the small gear in the middle is the sun gear, the internal gear (the one with the teeth on the inside also called the fixed gear) is called the ring gear.
2. the gear ratio for each stage is calculated as folows:
# of teeth on ring gear
------------------------------ + 1
# of teeth on sun gear
3. Multiply each stage's gear ratio together to get the total ratio. If in high speed, the second stage gear ratio is 1; so only multply the 1st and the 3rd stages.
-Paul
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
