Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 23-06-2002, 23:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
We got it to go half way too ... and here's how :-)
Posted by Shawn McMahon at 2/2/2001 8:11 PM EST
Student on team #263, Aftershock, from Sachem H.S. and Symbol, Citycorp., Apoge, CA ....
In Reply to: We go it to go half way...
Posted by Brian on 1/31/2001 9:17 PM EST:
It’s really quite simple to get the piston to stop half way. The valves last year worked because there was a neutral position. You can make a similar setup using 2 valves, one single and one double. Hook the double up to a cylinder like you normally would. Now plug both exhaust ports together and send that tube to the single switch. Sine it is spring loaded it will stay in its default position. Put a plug in the port where that air would normally come out. Now when you apply pressure to one side of the piston it will not move because you have effectively "plugged" the exhaust. To allow the piston to move, simply activate the single switch and the air is vented. Get it? The advantage to this system is that when the piston is stopped it is at full pressure, not atmosphere. A quick diagram of this setup can be seen by clicking on the link below. Have fun :-)
President of Team 263,
Shawn McMahon
P.S. Some people probably are not too happy that I disclosed this information. The way I see it, if I end up being allied with a robot that would benefit from a stoppable piston I have not only helped that team, but have also helped myself. I’m sure there are many teams who have already discovered a way to stop the piston. There are many ways. This is only 1 of 2 that I came up with.
[IMG] code is Off
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
double solenoid gail OCCRA 0 11-10-2002 19:42
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Solenoids archiver 2001 9 23-06-2002 23:47
