Go to Post Toughboxes are -- wait for it -- really Tough! - JesseK [more]
Unread 24-06-2002, 00:04
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Connecting hub sprockets to shafts
Posted by PAUL GIANNOSA at 2/2/2001 11:56 PM EST
Engineer on team #27, TEAM RUSH, from OSMTECH and TEXTRON AUTOMOTIVE CO..
In Reply to: Connecting hub sprockets to shafts
Posted by Patrick Dingle on 2/2/2001 7:17 PM EST:
: Does anyone know the most reliable way to connect a hub sprocket to a rotating shaft (no keyway)? We are planning to drill and tap the hub, and bolt slightly into the shaft. Is this reliable, or are there better ways?
: Thanks
: Patrick
HI PAT. JUST LOOKED @ SOME OF THE RESPONSES TO YOUR POST. I HAVE USED RAUL'S "DUTCHMAN" METHOD VERY SUCESSFULLY ON OUR WHEEL HUBS LAST YEAR AND I AM USING IT ON MY PLANETARY HUB WITCH REPLACES THE FRONT .5 OF THE DRILL MOTOR TRANS. THE DRILL SHAFT IS A CUSTOM ONE TURNED ON A LATHE FROM A GRADE 8 .75 BOLT. WE ARE ATTACHING A 16 TOOTH GEAR TO THE .472 DIA. SHAFT BY USING A DOWEL PIN. THE WAY I DID THAT ON LAST YEAR'S MACHINE WORKED REALLY WELL. WE NVR BROKE A GEAR OR SHAFT. WHAT I DO IS DRILL OUT THE 8/32 THREAD HOLE IN THE HUB TO .187 DIA. I DRILL AND TAP A LARGER 1/4-20 THD HOLE ON CENTER WITH THE .187 BORE. NEXT I BORE A .1875 DIA HOLE INTO THE .472 DIA DRILL SHAFT .200 DP. THIS IS SLIGHTLY LESS THAN HALF OF THE SHAFT. I CUT A .187 DOWEL TO FIT INTO THE GEAR AND SHAFT AND HOLD IT IN PLACE WITH THE 1/4-20 SET SCREW. I DON'T THINK YOU COULD GENERATE ENOUGH FORCE TO SHEAR A DOWEL PIN THAT IS ABOUT 45-55 ROCKWELL C. YOU ALSO MAINTIAN STRENGH IN THE SHAFT BY NOT BORING A HOLE COMPLETLY THROUGH. SORRY IF I'M A LITTLE WORDY. I CAN SEND YOU A AUTOCAD14 FILE SHOWING YOU GRAPHICALLY HOW I DO THIS. MY E-MAIL IS PMGRACER@AOL.COM
[IMG] code is Off
modifying sprockets gail OCCRA 3 05-10-2002 12:13
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
5/16" cold steel shafts... archiver 2001 3 23-06-2002 23:17
Which form of connecting a rod to a wheel is the best? SilverStar Technical Discussion 2 27-03-2002 20:30
