Go to Post The problem with random numbers is you never know. - GregT [more]
Unread 24-06-2002, 00:08
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Quick Question
Posted by Anton Abaya at 2/3/2001 5:30 PM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
In Reply to: Quick Question
Posted by Steve Cohen on 2/3/2001 5:25 PM EST:
: Is it true that we can use whatever type of controller we would like for our robot? I heard this from somewhere, and I just want to make sure it's true.
: Thanks in advance...
umm, when they say any type of controller, they mean any kind of PC COMPATIBLE joystick. good luck trying a WIDE range of stuff. you can use gamepads, joysticks (even force feedback...but double check with first), and even steering wheels and pedals.
they take some playing around with.
also, you can make your own from scratch....! make some aluminum, plexiglass (see through control sys!), or whatever else you can dream of...
good luck. (and always always check the rules.)
-anton
[IMG] code is Off
Quick <hr> question Jack Website Design/Showcase 1 31-01-2003 22:19
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
To all the ladies in the hiz-ous!! lol a quick question archiver 2001 1 24-06-2002 02:12
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
Quick Question, i guess Andrew Rudolph Motors 1 12-08-2001 14:39
