Go to Post when you think you are here to compete against other teams, thats when bad things start happening... - KenWittlief [more]
Unread 24-06-2002, 00:25
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: You are already done!
Posted by Gregory Ross at 2/7/2001 6:22 PM EST
Engineer on team #330, Beach Bots, from Hope Chapel Academy and NASA/JPL.
In Reply to: You are already done!
Posted by Eric Reed on 2/7/2001 3:57 PM EST:
: : Hi just wondering how to go about getting the second joystick to make a pwm go up or down, and the trigger and thumb buttons work as relays.
: : thanks,
: : Will Korinek
: : 646 Mechanical Animals
: It's already there. Joystick one controls PWM1, Joystick 2 PWM2, etc. through 4. Similarly, the buttons are already programmed to the relays. I think the trigger on joystick one sends relay one forward, and the thumbswitch sends relay one reverse...but that might be backwards.
: Good Luck,
: Eric
: Team 481
All this information can be found in the Control System Users Manual available on the Innovation First WWWeb site (Link below).
The default PWM controls are listed on page 27, and the relay controls are on page 28.
[IMG] code is Off
single joystick programming Bill Bonsky OCCRA 2 04-10-2003 09:47
Programming with the PBASIC Tokenizer Raven_Writer Programming 12 05-01-2003 15:27
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
joystick problem archiver 2000 12 23-06-2002 23:08
pbasic programming punarhero Programming 4 21-01-2002 23:32
