Go to Post Don't take my questions negatively, I just hold drive trains to a ridiculous standard. - AdamHeard [more]
Unread 24-06-2002, 00:34
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Debug function in programming?
Posted by Eric Reed at 2/9/2001 9:10 PM EST
Coach on team #481, NASA Ames / De Anza High School, from De Anza High School and It could be you!.
Howdy,
Can somebody tell me how to get the debug function to spit out a decimal (rather than ascii). Let's say we want to know the value of sensor1. I have tried:
debug sensor1 ' I get ascii
debug #sensor1 ' I get unrecognized character
debug "Sensor 1 = " sensor1 ' yup, ascii
debug "#sensor1" 'I get #sensor1
Help!
Thanks,
Eric
Team 481
#0047 (ChiefDelphi)
Re: Debug function in programming?
Posted by Matt Leese at 2/9/2001 9:42 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Fiber Technologies & RIT.
In Reply to: Debug function in programming?
Posted by Eric Reed on 2/9/2001 9:10 PM EST:
This is off the top of my head and with the disclaimer that I haven't touched any of the control system this year but I believe what you want is:
debug ? sensor1
Then again, I could be totally out of it. Check the PBasic manual.
Matt
#0047 (ChiefDelphi)
debug dec variablename
Posted by Joe Johnson at 2/9/2001 9:53 PM EST
By decimal I assume you mean the ascii for the
characters that display the value of the variable in
decimal.
variablename var byte
variablename = 0
Main:
debug hex2 variablename, " ", bin8 variablename, "
",dec variablename, " ",cr
variablename = variablename + 1
Goto Main
The above code would pin
00 00000000 0
01 00000001 1
02 00000010 2
03 00000011 3
04 00000100 4
05 00000101 5
06 00000110 6
07 00000111 7
08 00001000 8
09 00001001 9
0A 00001010 10
FE 11111110 254
FF 11111111 255
00 00000000 0
01 00000001 1
02 00000010 2
If you don't have the PBASIC manual, buy one. I bought
Version 2.0 of the manual (new this year) and I am very
happy with it. It is a pretty big improvement over
Version 1.9 in my opinion. Worth the price.
Good luck.
Joe J.
#0047 (ChiefDelphi)
Posted by Stephen at 2/9/2001 9:57 PM EST
Other on team #122, NASA Knights, from Grafton High School (Robotics team is at NHGS) and NASA.
here's how you do it:
debug "var", dec var, cr
where dec means decimal, hex would mean hexadecimal, etc.
#0047 (ChiefDelphi)
Thanks, All
Posted by Eric Reed at 2/11/2001 3:24 AM EST
Thanks, all. That is exactly what I needed. For some reason the manual that comes with the kit does not properly address this (and many other things)
Eric.
[IMG] code is Off
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
variable? manodrum Programming 11 01-04-2003 17:20
basic stamp editor debug capture dave_l Programming 4 17-03-2003 19:35
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
