Go to Post I'm a product of the 60's and react accordingly...I have an entire portion of my brain filled with song lyrics from the 60's and 70's which causes me to not have room for important stuff like motors, pneumatics, electrical system and green lights... - RoboMom [more]
Unread 24-06-2002, 00:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
burning smells are not usually good
Posted by Joe Ross at 2/16/2001 4:43 AM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
In Reply to: Rookie Question. double solenoids...
Posted by Anton Abaya on 2/16/2001 1:44 AM EST:
: we are trying to hook up the double solenoid to ONE Spike. i dont know electrical stuff (deprived i know) and let some1 else do it (for once). we tried it and we smelt something burning (on the solenoid) so we turned it off.
: we did it exactly the way the manual says we should do it with the diodes and all....
: did anyone else do this? or should i just go get a darn spike?
: and if i just use another spike, can i use last year's?
I'm not sure what you might have done ;-) My first thought was that you inserted a diode backwards, but if that were the case the solenoid probably wouldn't have worked, but shouldn't have burned. There was probably a short somewhere, thats the only thing that I can think of that might cause burning.
The simplest solution (unless you want to try it with the diodes again) would be to use 2 spikes. You are allowed to use spikes from last year. This does assume that the double solenoid still works.
[IMG] code is Off
Double Solenoids - assembly. Frank(Aflak) Pneumatics 9 06-02-2003 20:33
Missing parts rookie question groves Kit & Additional Hardware 3 13-01-2003 22:55
Rookie question archiver 2001 8 23-06-2002 23:21
DOUBLE QUESTION OF THE WEEK!!! [01-30-02] Ken Leung Rumor Mill 11 04-02-2002 13:01
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
