Go to Post Above all, have fun and, if you need help, ask for it... Your inspectors will be glad to help or try to arrange for another team to help you. This should not be a traumatic experience! - Mike Betts [more]
Unread 24-06-2002, 02:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: tether after a match
Posted by Chris Hardman at 03/11/2001 10:50 PM EST
Student on team #111, WILDSTANG, from Rolling Meadows and Wheeling High schools and motorola.
In Reply to: Re: tether after a match
Posted by joe frick on 03/11/2001 10:44 PM EST:
: : : does anyone know if it is legal to hook up a tether after the end of the match to collapse a robot, i would be using a seperate control system(last years), to collapse our robot in order to remove it from the field without hassle if we should end the match in the uprite position. thank you
: : yes- as long as your robot is off the field, we had to do this a couple of times to reset our robot for the finals mathces and when we had matches right after each other.
: : chris hardman
: so we would have to carry it off the field ,say just over the rail then hook up, even if its 10 feet tall at the time we shut down
yes, like the other posts say, you need to alter your robot so you wont have this problem ours is 4 ft wide and possibly 6 ft long at the end of the match
[IMG] code is Off
Thanks 968 and 294 and last match LA sanddrag Regional Competitions 5 16-04-2003 17:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
Average match score?!?! archiver 2001 9 23-06-2002 23:04
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
Avg Score CMC General Forum 14 12-03-2002 07:23
