Go to Post A FIRST door is always open. - Chris Fultz [more]
Unread 24-06-2002, 02:10
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: NEED HELP with Delay loop for compressor relay switch
Posted by Mike Gray at 03/12/2001 2:20 PM EST
Engineer on team HOT from Huron Valley Schools sponsored by GM Milford Proving Ground.
In Reply to: NEED HELP with Delay loop for compressor relay switch
Posted by Erik on 03/12/2001 11:54 AM EST:
Here's one way to do it. Simple, and uses only one byte.
First declare a new variable and initialize it:
compdelay var byte
compdelay=1
Set the upper limit constant
complimit con 30
Increment or decrement the variable as a function of rc_sw1 (or whatever input you use).
compdelay=compdelay+rc_sw1 - (1-rc_sw1) min 1 max
complimit
Then add a LOOKDOWN table to the main loop:
lookdown compdelay,
[IMG] code is Off
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
1 or 2 phase switch archiver 2001 0 24-06-2002 00:48
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
