Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 07-06-2001, 06:08
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Question what about the drill motors?
Does anyone spent anymore time looking at those drill motors about the problem with demagnetization, or simply gone weaker under a huge load?
Is it possible that we will be facing the same problem next year? I don't suppose there's anyway of fixing the problem... Is it true that the problem only happen on re-magnetized drill motors?
By the way, do people think that FIRST will keep using the same drill motors next year? It was a rumor from the year before, and we end up with the same motors 2001...
Unread 10-06-2001, 01:27
I can't say anything about demagnetization, but I can't imagine FIRST getting rid of the current drill motors without replacing them with something else as (or more) powerfull.
Can you imagine trying to balance using only the FP motors to drive?
Unread 26-06-2001, 02:11
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
I agree that they won' replace them with something that fits in that niche.
The drill motors have the highest power output of any of the motors in the kit.
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
Blowing drill motors archiver 2000 6 23-06-2002 21:58
