Go to Post Iteration is a necessary but not sufficient criteria to being a powerhouse team. - Chris is me [more]
Unread 01-07-2002, 14:17
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
Just to clear things up, if you drop below 9 volts in the default program then the low battery light will blink. You can always change the constant dataInitVolt to set the voltage you want the light to start blinking on. From the default code, here's the equation:
VOLTAGE = INT ((DESIRED FLASH VOLTAGE + 0.4) * 16.3)
Stephen
[edit]
PS. this is also from the default code:
If you see a BASIC INIT ERR on the Robot Controller after programming and pressing RESET, then there is a problem with the Serin command
[/edit]
