Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 06-11-2001, 10:14
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
20 Degree Pressure Angle
The gear on that motor is a 20 Degree Pressure Angle gear.
The gear is 12 Tooth, 16 Diametral Pitch, Stub, 20 Degree Pressure Angle,
The gear is a "Stub" tooth gear, but it can mate okay with a full depth gear if you increase the center distance a bit from the theoretical number. Another option is to put shave the OD of the standard gear by .4"/DP, which in this case is .4/20 or .020"
If you are making your own gear, then of course, just make the gear a stub gear to begin with -- (.8/DP for the addendum, 1/DP for the dedendum).
Good Luck.
Joe J.
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
The window motor is being mean to me... archiver 2001 2 24-06-2002 03:02
window motor archiver 1999 0 23-06-2002 21:52
