Go to Post A FIRST fanatic who never had any desire to be an engineer. There. I said it. ;) - Katie Reynolds [more]
Unread 06-11-2001, 11:15
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
simple engineering question
I'm working on a LEGO Mindstorms bot, and I have two motoers using 12tooth bevel gears to use one output shaft to turn two, wich in turn turn tow more, which move the wheels (in essence: one moter per two wheels.
I'm mounted a claw, which is powered by a geabox, but i need more torque in the drive system. I was thinking of improving the ratio from 1:1 (12t to 12t) to 1:3 (8:24) but i have a 12t bevel on the same shaft as the 24.
my question is this: is there a formula for finding out the gear ratios of gears on different shafts, when a third gear to being powered by the first?
Think of it as an 8t gear, driven by a motor, turning a 24t gear, turning a sahft with a 12t bevel. How much torque am i getting? is there a formula out there? I've looked all over the 'net, and can't find a thing. Thanks.
--Ben Mitchell
Unread 06-11-2001, 12:39
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
the most simple equation I can think of
Well... The most simple equation I can think of is the equation of power:
Power = Force X Velocity, and in your case of gears, Power = Torque X Angular Velocity.
Assuming those Lego motors have constant power if you keep the battery fresh, you can use this formula to choose what gears to use.
The easiest way is to count the teeth of gears. Say, originally you use a 12 teeth gear on the output shaft of the motor driving another 12 teeth gear, and that generate a certain amount of force. If you want to increase the force, all you have to do is keep the same gear on the motor, and use a bigger gear with more tooth on the other shaft, or reduce the size of the gear on the motor...
Just think of it this way. If you switch the gear on the other shaft to a 24 teeth gear, which mean now in this stage you are using a 12 teeth gear to drive a 24 tooth gear, then for every turn the motor make, the other gear/shaft is going to turn half a turn, because the 12 teeth would only grip half the tooth on the bigger gear. So that mean, on the 24 tooth gear, the angular velocity is now 1/2.
Since it is almost constant power coming from motor, and Power = Torque X angular velocity,
Power = ? Torque X 1/2 Angular Velocity, solving for ?, you will see that there will be twice the torque for this equation to balance.
So to answer your original question. When you switch ratio from 1:1 to 1:3, you get three times the torque, and in return, the 24 teeth gear is 3 times slower.
Also, when you say you have a 12 teeth gear on the same shaft as the 24, as long as you keep the original gear that the 12 teeth gear is on contact with, then you won't be changing the torque on that stage. So, over all, by switching from 12t to 12t into 8t to 24t, you are increasing the torque by a factor of three.
I hope I didn't make this too complicated.
Unread 07-11-2001, 07:50
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
Try the Tech Library at qtcgears.com. Go down to page 384 "Gear Trains", then go to the next page in that series. Figure 13.3 shows a three-gear train, and the formula for speed ratios. You will see that the idler gear (the one in the middle) does not figure in the speed ratio formula. Also, note that torque ratio is the inverse of speed ratio - if the speed ratio is 3:1, the torque ratio would be 1:3, and so forth.
This library of gear information tells you more than you will ever need to know about gears.
Leo M.
Simple question for blog/livejournal/etc users.. Joel J Chit-Chat 7 18-07-2003 02:38
Auton Mode simple question Morgoth Programming 7 10-02-2003 10:10
simple question... answer it archiver 2001 1 24-06-2002 01:02
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Canvas in Delphi - Simple question archiver 2000 1 24-06-2002 00:30
