Go to Post FIRST is again mirroring real life. And in real life, when we build and design robotic and automated systems, it's safety first. Hitting a human in real life loses a lot more than 30 points. - Fred Agnir [more]
View Poll Results: What do you use for chassis material?
wood 11 5.07%
steel angle 8 3.69%
aluminum angle 36 16.59%
steel tubing (round or rectangular) 2 0.92%
aluminum tubing (round or rectangular) 58 26.73%
Bosch extrusion or similar (aluminum or steel) 89 41.01%
Other 13 5.99%
Voters: 217. You may not vote on this poll
Unread 11-08-2002, 01:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Chassis Material/Construction
This is my effort to make a meaningful thread.
I am interested in what all the teams use to make their chassis. We have always used Bosch extrusion and will be using it again next season. What do you use and what are the pros and cons of different materials?
Unread 11-08-2002, 09:21
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
All steel for us. We had a welded steel frame this year and it worked very well for us. It weighted a ton, and probably limited our design, but it was strong, cheap, and easy to work with. We have used aluminum channel and tubing before (2001 and our off-season OCCRA competition), but we like steel better, and we can get it fast and cheap locally.
Jeff Waegelin
Unread 11-08-2002, 11:21
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
/me <3 extruded aluminum
very useful when you design and build the chassis, then realize it sucks, and redesign it and rebuild it, then realize it sucks...
AIM --> Woloi
Email --> ian@woloschin.com
Unread 11-08-2002, 17:51
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
We don't use any of that we, use 1/4 Aluminium plating with alot of holes in it. Makes for a very rugged robot.
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 11-08-2002, 19:13
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Hmm...I think we use 1"x1.5" aluminum rectangular tubing. Not too sure on the dimensions. It's sturdy. Uhh...and it's sturdy.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 11-08-2002, 19:23
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Extrusion
The past couple years all we've used is different assortments of extrusion....This year we used more "aluminium tubing"(still extrusion?) because of weight.
Example:
http://www.chiefdelphi.com/forums/at...=&postid=13472
Purdue Alumni
Cummins, Inc.
Unread 11-08-2002, 22:02
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
We used 1/4" aluminum plate with 1/4" aluminum angle underneath for sturdiness. We also have a 1/4" aluminum angle V-cut in the front of our robot for handling goals. It's sad though - it's way too strong. Our engineer used it as a trampoline after he made it until his ankles hurt, but now we've cut too many holes in it for it to be used that way again.
Next year, bring on the extrusion and tubing! Let's go for a frame, not a plate, woo!
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 11-08-2002, 22:23
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Sounds about right, or at least something close. Don't forget our steel anti-bumpers. Moe found out about them to well this year, there are still traces of them finding out about our anti-bumpers. Ohh yeah... it's sturdy!
Unread 11-08-2002, 22:57
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
We've used aluminum angle , extrusion, and angle iron.
We stoped using the aluminum angle because our welding teacher retired and we have no idea how to mig or tig weld(tried it once the results were not pretty) so we switched to angle iron which was much easier to weld, but weighed a ton. This year we used 80/20 extrusion which was nice and modular but was heavy also.
So out of my expieriance the best framing material is some sort of aluminum structural material like box or angle that you weld together because you just can't get a stronger lighter frame that actually allows you to put other mechanisms for the other part of the game on the robot.
Build first ask questions later.
Unread 11-08-2002, 23:00
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
This past year, we used 30mm x 30mm Boasch aluminum extrusion. It's sturdy, it connects well and we get a discount on it!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 11-08-2002, 23:16
D@ve's Avatar
D@ve D@ve is offline
Make it Happen
AKA: David Ferreira
FRC #0078 (Air Strike)
D@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of light
Send a message via AIM to D@ve
We always go by are moto ( Wood is good , Steal is real , and plastics fantastic ) just to share a little humor with you guy !
Unread 11-08-2002, 23:32
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
We used Bosch, because the team welder graduated last year.
It's great stuff to use, you can build a bot in no time, and disassemble it easily... but it adds unneeded weight. You could probabaly use 2 bars of aluminum tube for every 1 Bosch, and still have it weigh less and be just as strong.
But, hey, it worked great for us, so I'm not complaining.
Heh, it'd be sweet if someone built their bot outta polycarb. That'd be rather fragile tho. Just get some nice 3/4" thick polycarb
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 11-08-2002, 23:43
The bosch aluminum extrusions are not much heavier than the same size square tube with an average wall thickness. The extrusions are great for changing design, quickly adding mechanisms, and moving pieces without drilling. It's a snap to build and makes the whole project more modular. It is incredibly strong too. Also, its only a couple of bucks more than sq. tube.
The only downside is the cost of hardware. Those little brass alloy T-nuts are like 50 cents apiece. There's also the wierd metric hardware that's a little more money and harder to get then American hardware. The joiner plates are just a rip off so we make our own.
For those of you who voted wood, can we see some pics?
Unread 12-08-2002, 10:38
Robogeek
Somebody did. In 2001 (I think Adam knows this story better than I) they only used Lexan as a building material. They made 1/4" lexan angle, lexan sidepanels, and everything like that. No structural steel or aluminum at all.
It was pretty cool looking
EDIT:
Forgot to mention who it was! It was team 401. We were next to them in the pits at VCU, so I remember them lifting up lexan parts of their robot I could see through while we worked.
Gui Cavalcanti
Unread 12-08-2002, 13:07
El Jefe de 148
Yeah, but in 2001, you could get away with that. The structural concerns were not as great when you knew you weren't going to be in contact with opposing bots.
Jeff Waegelin
Image Discuss: Team 190 - Completed chassis CD47-Bot Robot Showcase 17 20-02-2003 17:37
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Sheet Aluminum Chassis: fs_2002 Technical Discussion 4 17-10-2002 10:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
