Go to Post Angry Teams will not get the field going any quicker trust me on that! - mtaman02 [more]
Unread 09-11-2001, 14:02
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Small Step toward signed math...
Small step toward signed math:
The main reason I want to use signed math is I want my division to work out properly. In 2's complement math, adds, subtracts, and multiplies take care of themselves (mostly). It is the divide operation that give folks the hassles.
How about if you could tag a part of an expression that may be of unknown sign and then the code could get the math right.
For example:
PWMoutput = (error term) * FeedbackGain >> FeedbackScaling + $7F MAX $FE + $8000 MIN $8000 - $8000
If would be nice if I could flag (error term) as signed for the purposes of the division ">> FeedbackScaling"
The pre-processor could then put in the right IFs, Tests, Gotos, etc. that are typically required to get the division to work right.
It would also be nice to an automatic way to make sure that the results are within the right range for an 8 bit PWM output, eliminating the need for all the MAX's & MIN's and $8000's
Just a thought.
Joe J.
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
emulationFIRST (aka PBasic emulator) Matt Leese Programming 5 30-06-2002 12:06
PBASIC Loop Speed? archiver 2001 3 23-06-2002 23:46
