Go to Post No matter what happens to the robot we learned our lesson and we had fun. That's what matters. - David Guzman [more]
Unread 14-11-2001, 20:49
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I have NEVER had a Victor require Recalibration -- in 4 years!
IT IS ALMOST CERTAINLY NOT CALIBRATION!
If your motors are getting tired it is probably because you are using the Keyang motors and they have a breaker inside of them that cuts the voltage when the motors get too hot.
Check the lights on the Victor. If when you give them full gas, you see a green LED and when you go full reverse you get a red LED, then it is very likely that the Victors are working just fine.
Your will have relax your driving style or get a better ratio on your motors or find some other way to keep your motors from overheating.
Call me if you have continued problems --- Don't forget to read the message titled "DON'T RECALIBRATE YOUR VICTORS!"
I MEAN IT!
Joe J.
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
