Go to Post If you squeeze cost out hard enough, any component can become a failure point. - EricVanWyk [more]
Unread 14-11-2001, 23:00
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Check for a short between heatsink and fan wires.
Okay, this may sound dumb, and it is, but I did it once. When connecting your fan to the power screws, make sure that the positive wire doesn't touch the heatsink -- it's negative! Doing so will short the victor, partially or fully fragging it. You probably won't even notice it until it's too late, like during a match. The Victor will perform erratically or just plain not function in certain situations, all of which are unique to the fragged Victor. Also, it's not the most Kosher thing to attach a variable current motor to a Spike; I'd advise against using it for long periods. But the number one thing to do is check your wiring before you turn it on and NEVER EVER DO WIRING WHILE IT'S HOT!!!!!!
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
