Has anyone done actual dyno tests on some of these motors to confirm that the "½ Free Speed X ½ Stall Torque" based calculation is reasonably accurate? I assume that the calculation should be fairly close to actual output, but I'm curious as to how close. The actual output might be higher than a calc. based on stall torque because the commutator timing is set to optimize the motor for some rpm greater than zero in the "forward" direction.
| reducing gear box weight | mickjagger | Technical Discussion | 16 | 23-01-2003 20:35 |
| Gear Box Parts Posted on First Cad Library | Ed Sparks | Inventor | 1 | 10-01-2003 01:54 |
| Please help! Grease in the drill motor gear box? | archiver | 2000 | 2 | 23-06-2002 23:07 |
| Grease inside the Drill Motor gear box? | archiver | 2000 | 2 | 23-06-2002 23:07 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
