Flexible semi-pourous materials...
There are some flexible, semi-pourous sheet plastics that would hold the air and let some out for cushioning and the ability to use the pump constantly. But if you're really going for a simple, easy, cheap, light skirt that works, go with two layers of vynl tarp with evenly spaced holes along the nbottoms of each layer, making sure that the holes are not directly above one another so that you get maximum air cushion. Personally, I like the tarp, because it's cheap and easy to replace when torn.
| tank treads vs. threaded wheels | lj8758 | Technical Discussion | 14 | 24-01-2003 00:30 |
| Wheels or Treads | redbeard0531 | Technical Discussion | 21 | 13-01-2003 21:05 |
| Tank treads and specialty wheels | archiver | 2001 | 7 | 24-06-2002 01:25 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
