Go to Post Successful teams - in almost any aspect of life (i.e. not just robotics) - don't make excuses and assign blame when something goes wrong. They improvise. They adapt. They overcome. They correct the problem and move on. - dlavery [more]
Unread 08-10-2002, 21:41
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
No, you have to make a key and have trench-like section removed from the shaft for the key.
Yes. The shaft has the key, and whatever you are attaching has a hole for the key.
so the keyway is the trench like thingo on the wheel/gear and an lump on the shaft. ok. i get that. But one problem i forsee would be attaching the keyway. Would it just be like a flat piece of metal screwed on to a shaft, or would it have to be welded? Also, cutting out trench from the wheels/gears would be a daunting task to do accuratley. I think that I would use the miller, but i dont know if it will be precise enough to be effective in transfering the power without vibration.
if anyone has a link to pictures of this, that would help me immensley.
tenkai
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
3D Model of skyway 20" wheelchair wheel?? Elgin Clock 3D Animation and Competition 2 14-09-2002 16:41
