Go to Post [This year's game manual contains] 46 new pages of pictures displaying how to attach bumpers, assuring at least 15% of teams almost get it right this time. - PayneTrain [more]
View Poll Results: What do you use for chassis material?
wood 11 5.07%
steel angle 8 3.69%
aluminum angle 36 16.59%
steel tubing (round or rectangular) 2 0.92%
aluminum tubing (round or rectangular) 58 26.73%
Bosch extrusion or similar (aluminum or steel) 89 41.01%
Other 13 5.99%
Voters: 217. You may not vote on this poll
Unread 12-08-2002, 16:05
Matt Reiland's Avatar
'The' drive behind the drive
We noticed some NASA teams that pre-made connectors (like tinker toy ends) that hold tubing at different angles in the off season. THe keys here is build your 'proto-type' out of BOSCH then make the final out of tube by quickly rebuilding straight tube sections fitted into the pre-made connectors and giving it a little weld, which is much faster than making the custom ends on each piece when time is an issue. We will probably do this for 2003.
Bosch is great stuff, it just weighs alot, we did find we could 'remove' some excess material from sides we weren't attaching to for weight savings and it still was pretty strong stuff.
30x30mm
Unread 13-08-2002, 16:36
Generator of Entropy
FRC #2973 (The Mad Rockers)
Love that Lexan
We've been using polycarbonate for several years now - I don't think anyone would accuse us of being fragile. This year our front frame was aluminum tubing and center pan was aluminum sheet, but most of the rest of the chassis (including the gearbox housings) were Lexan. It's easy to machine and assemble - it taps very easily for individual brackets and we use self tapping drywall screws for general assembly. A couple lessons learned - grease the screws and don't use locktite - it will shatter the laminate when it heats and cures. A key thing to remember in battle is that low spring rate materials will absorb impact energy better than stiff materials and lexan does a great job.
Unread 04-09-2002, 16:46
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
wheelman already said what we use
Badjokeguy
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 12-09-2002, 12:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
God Bless 80-20! SEE IT HERE! We usually go for the 1"x1" extruded 80-20 with 1/4 inch aluminum plate for the body. And also some 2"X 2" as well.
see example here and here
Unread 12-09-2002, 19:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Yeah, we got some free samples of that stuff.
Could you explain a little about the "castors and one wheel on each side of your robot thing" I see in the picture?
Unread 14-09-2002, 01:58
sidewinder sidewinder is offline
#0066 (Those medeling penquins)
sidewinder is an unknown quantity at this point
Too heavy
I represent team 66. We build the sturdiest drive chassies i've ever seen, and can rarely be beaten. It is a little know fact that our robot for this last year was actually meant to handle balls. we only had one problem, a 95 lb drive chassy. We are big fans of the 1" extrusion but in my pit scouting for the last few years i have noticed something, The robots built for first don;t have enough power to bend 1" extrusion with any kind of blow.
I beleive that 20 mm extrusion, very light by comparison to its big brothers, has more than enough strength for our purposes.
As for polymers in construction, i haven;t seen many good examples of structural framing comming from it but have seen it in many good low impact uses (33's ball carrier a prime example. But after seeing the plastic bot of, i believe, 49 fall over at grand rapids last year and loose its arm, i have been weary of plastics use for robots.
Unread 16-09-2002, 12:18
Simple, pneumatically controlled drive systems. One primary drive, and one secondary drive. The pneumatic wheels are the drive wheels hence 4 of them, two drive each configuration. The castors are just there for balance. It is a thing of beauty, no need to have a wide turning radius. We just switch drive systems and drive in a 90 degree angle from the original heading. It all worked with our I.D.A.N. System described below.
"A mini press release if you will:
The 2002 Robot
The Watertown High School Sie-H2O-Bots have created the 2002 PAL (Professionally Automated Landrover) to be a combination of simplicity and robustness. The machine uses a total of eight motors to function. These motors include three Bosch drill motors with planetary gear transmissions, one Fischer-Price motor with a custom built planetary gear transmission, two power window drive motors, one air compressor with 120 psi capacity, and one small servo motor. The final product is a durable, fast robot with good maneuverability.
The robot consists of two operating systems controlled via remote control through a computer-generated program. The two systems control the locomotion of the robot as well as a grasping system to capture and release goals. These two systems will allow the team to score points on the field by maneuvering the goals into different positions of the field.
PAL 2002 utilizes a 4-wheel drive system. The primary drive system consists of two wheels located on the east and west sides of the robot. These propel it forward and backward with tank style steering via two flight sticks in the driver’s hands. Speed is achieved with the click of a button, which activates two small air cylinders, shifting the drill motor drives from low to high range and vice versa.
The secondary drive system wheels are located on the north and south side of the robot. They are engaged when the primary drive wheels are raised off the floor and the secondary drive system is lowered. In this position, the robot moves from side to side. The tank-style steering drives are toggled by the student driver who, at his or her discretion, regulates the speed, power, and direction they deem necessary. During driver training, the ability of the robot to rotate around the goals proved to be a valuable asset. It enabled the robot under strong power to slip out of normally pinned positions with other ambitious robots.
A pneumatic system consisting of an air pump, storage tanks, regulators, valves, flow controls, and actuator cylinders is used to give the driver the luxury of switching drives instantly at the squeeze of a trigger.
The grasping systems consists of two “fork plates” that are located on the north and south side of the robot. They are ¼” aluminum plate shaped like a fork. The controls are designed to deport the fork arms by raising them vertical to horizontal from the profile of the robot, like short wings. When driven into the goal structures, the arms will automatically grab and hook the goal. The second driver controls each fork arm independently with a small control box at the driver station. Lowering the arms and driving the robot away releases the goal.
The team’s very ambitious electrical team has developed sophisticated controls, wiring, and programming to navigate the machine. The navigational system compliments the robot design very well. Important symbiotic relationships continue to develop between the electrical and mechanical systems as well as between the drivers and driver feedback systems.
The electrical team of students and engineers has created a system that would enable independent control of the machine by a visually impaired driver. Code named I.D.A.N. (Intelligent Detection, Analysis and Navigation), the system allows the robot to provide audio feedback to a laptop computer.
The cornerstone of this system is a tiny magnetic sensor that will read the earth’s magnetic field. The signal it sends out will identify the direction the robot is facing. This information also establishes the robot’s location within the five zones of the playing field. An optical switch receives a signal every time the robot moves over a line of white tape bordering each zone.
The robot has been installed with optical switches on servomotors, which allow it to “scan” for the goals and correct its path automatically. The optical switches respond to the retro-reflective properties of the tape on each goal. A pressure sensor inside the robot arms will determine that the goal is secure. The Sie-H2O-Bot team looks forward to gaining extremely valuable experience with this very sophisticated system as the season progresses.
Our experimental "Blind Drive" system won us the leadership in controls award in NYC as well."
Unread 18-09-2002, 14:34
Joe Menassa Joe Menassa is offline
Professional Photographer
FRC #0078 (Air Strike)
Joe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud of
Send a message via AIM to Joe Menassa
wood all the way. why, because its inexpensive and does the job. We were attacked left and right this year, slamming into everything and the wood did not bugde. Our team loves it.
Joe Menassa
FRC 78
Unread 23-09-2002, 15:26
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We used 1.5" Steel angle this year, because some genius thought that we would really need the extra strength. In reality our frame weighed a TON more than it should have. In the past we have used 1.5" aluminum angle, and it worked great.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-10-2002, 18:09
Tarzan Tarzan is offline
#0093 (New Apple Corps)
Tarzan is an unknown quantity at this point
bosch is good bwa-hahaha
Unread 01-10-2002, 19:07
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
80/20 is better (And no its not because our main sponsor sells over a million dollars of it a year and gives it to use for free)
Build first ask questions later.
Unread 08-10-2002, 21:10
mpking's Avatar
mpking mpking is offline
AKA: Mike
#0088 (TJ²)
mpking is an unknown quantity at this point
Send a message via AIM to mpking
We've been all across the board.
96. ALL WOOD. Even the wheels!
97. Wood/Steel frame Hybrid. This bot Rocked! 2nd place in NJ
98. All Steel frame, all alumin upper chassis. 2nd in NJ again
99. again, all steel, and alumnin upper chassis
00. Aluminin Frame. Actually, the whole bot was aluminin
01. Aluminin / Bosch Hybrid
02. All Bosch. She was a tad heavy, but we have never had a bot that wasn't within a few ounces of the limit.
Another funny correlation. 96 and 02 had the same drive train, two wheels.
all the other years had skid steer. (Think like a tank)
Mike King
Bridgewater Raynham Regional High School
Team 88 TJ²
The Home of Moe
Unread 08-10-2002, 21:16
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We like steel. Our two most successful robots have hade a steel frame. We used aluminum, too, for our mast in 2000, but 2002 was all steel. It was ridiculously heavy, but for our simple but effective design, it was perfect. We took a heavy beating, but the only damage was superficial damage to our Lexan paneling.
We've done wood and aluminum, too. Our 1998, 2001, and OCCRA bots are all wood/aluminum hybrids. We make an aluminum frame and put in a wood base and side walls.
Jeff Waegelin
Unread 11-10-2002, 23:40
MacZealot MacZealot is offline
MacZealot is an unknown quantity at this point
Send a message via AIM to MacZealot
When I heard chassis I thought it was a computer chassis or such.
DUH!
Anyway, aluminum tube, it's stronger and lightweight.
AIM: Joe7464685192 | Email Me! Visit my site!
Uh I'm STILL not in Las vegas GRRRR!! I dun think it'll happen till june and This shoulda happened a freaking year ago
Unread 14-11-2002, 21:56
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
Post Chassis
Some of you said that polycarb was brittle and or shatterd easily, those people are confuseing polycarbonate(aka lexan) with acrylic. Acrylic is very brittle, which was best demonstrated at the seatle regional when a team had a scoop made out of acrylic and the opposing alliance threw a ball into play, and it hit the scoop, the scoop shattered. Polycarb on the other hand is extremly tough in fact it is used instead of plate glass in prisons and things of that nature. I saw a demo of polycarb on TV where they invited members of the LA SWAT team to try and break the stuff. The SWAT team tried to break it with sledges, axes, pipes, and crowbars and failed miserably. So they came back with their automatic weapons and fired on the stuff with MP5 sub-mchine guns (NO JOKE) and the polycarb stopped every bulleto a full 30-round mag!! So polycarb(aka lexan) is extremely tough and has no problem holding up to any and all FIRST applications.
My team used extruded aluminum for our base in the form of a "c" shaped structure which was temporaily bolted together for testing and then was TIG welded at the end of testing. Then we built up from there with alum. angle. Then a plywood base to mount ball gathering mechanism and electronics. Why did we use plywood you may ask, because it as avalible and it is so much easier to work with then metal will ever be. Even though it is ugly as can be. On top of the plywood we used alum angle for the ball hopper which filled out the maximum allowed space.
Image Discuss: Team 190 - Completed chassis CD47-Bot Robot Showcase 17 20-02-2003 17:37
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Sheet Aluminum Chassis: fs_2002 Technical Discussion 4 17-10-2002 10:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
