Go to Post I urge them to build the kitbot and repeateadly smash it into a concrete wall in order to sate their anger. It will soon wane when they manage to do more damage to the wall than to the kitbot. That is honestly the reason that we ended up using the kitframe this year. - Andrew Blair [more]
Go Back   Chief Delphi > Competition > OCCRA
  #31   Spotlight this post!
Unread 08-10-2002, 17:50
C Fox C Fox is offline
#0247 (Da' Bears)
C Fox is an unknown quantity at this point
Send a message via AIM to C Fox
Tower
I have some more questions about the tower.
1.) What are the dimensions of the ring that goes on top of the small tower?
2.) Since the small tower and the big tower seems to share a floor flange in the drawing, how does the ring attach to the small tower but not obstruct the larger tower?
3.) Does it matter whether the casters are fixed caster or pivot casters?
4.) Is ther a final answer on how to attach the center pivot yet?
5.) Why does the CAD drawing say we need 20 floor flanges? The drawing doens't show nearly that many
-C.Fox
  #32   Spotlight this post!
Unread 14-10-2002, 20:46
#0247 (Da' Bears)
WE NEED ANSWERS!
Since we don't have the answers to the questions above, our team's building is being delayed. We need answers fast. Any help would be greatly appreciated.
-C.Fox
  #33   Spotlight this post!
Unread 14-10-2002, 20:52
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Answers
Call and talk to Justin at OTC. He made the cad drawings from sketches that Jim Zontag made.
Mike Martus
  #34   Spotlight this post!
Unread 14-10-2002, 23:15
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
Goal Tower Info.
I do not know all the answers now, but when I get to school tomorrow I will check on them; here are the ones that I do know:
A HOLE IS CUT IN THE RING OF THE SMALL TOWER AND THE PVC OF THE TALL TOWER PASSES RIGHT THROUGH IT; SEE THE ATTACHED PICTURE
THE CART CASTERS ARE 2.5" SWIVEL TYPE, THE GOAL TOWER USES 2.5" FIXED TYPE
A FLOOR FLANGE IS BOLTED TO THE LOWER PLYWOOD, A PIPE THREADED ON BOTH ENDS, CALLED A NIPPLE, IS THREADED ON TO THIS FLANGE, THE UPPER PLYWOOD IS SET OVER THE PIPE SO THAT THE NIPPLE PASSES THROUGH A HOLE IN THE CENTER OF THE UPPER PLYWOOD, AND FINALLY, A FLOOR FLANGE IS INVERTED AND THREADED ONTO THE TOP OF THE NIPPLE.
IT TAKES 12 FLANGES TO BUILD THE GOAL TOWER AND 8 FLANGES TO BUILD THE TWO CARTS.
  #35   Spotlight this post!
Unread 15-10-2002, 11:18
Justin Howard Justin Howard is offline
Justin Howard is an unknown quantity at this point
I truly apologize. I just sent drawings to Brandon to post on the white pages but the measurements to the rings are 11.5 I.D. and 16 O.D.
  #36   Spotlight this post!
Unread 15-10-2002, 11:33
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
u can use illustrator to open those files. I have tried it and u can see the files.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Autocad drawings Jimmy Holmes OCCRA 3 25-09-2003 18:45
New(er) AutoCAD drawings... Brandon Martus OCCRA 1 16-10-2002 14:34
AutoCAD Viewer Gadget470 OCCRA 2 25-09-2002 03:19
Help with Autocad and Bryce 5 Keith Chester Inventor 0 25-03-2002 17:33
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
