Go to Post Once you get to college, remember that FRC is not your life anymore (or at least it doesn't have to be). Don't be afraid to try new things, and branch away from the things you swear by in high school - buildmaster5000 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:14
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Air cylinders
Posted by Jason Baker.
Student on team #240, Mach V, from Jefferson High School and Visteon.
Posted on 10/24/2000 6:24 PM MST
as we all know, the pnuematic cylinders will not retain air pressure after the pump is shut off. so..., my question is, we have some air line inserts that only allow air to flow one way, can we use these?
#0047 (ChiefDelphi)
Q&A Air Cylinder
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 10/24/2000 6:54 PM MST
In Reply to: Air cylinders posted by Jason Baker on 10/24/2000 6:24 PM MST:
Question:
As we all know, the pnuematic cylinders will not retain air pressure after the pump is shut off. so..., my question is, we have some air line inserts that only allow air to flow one way, can we use these?
Answer:
Not this year. Do you have a part number & a cost. Maybe Next year.
P.S. There is no rule against kinking the Tygon Tubing. -- Just a thought.
[IMG] code is Off
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Air Fare to Florida archiver 2000 0 23-06-2002 22:16
Beatty and Kingman JAlpert Regional Competitions 51 08-04-2002 16:59
servos, chapulas, cylinders and Skyway...in other words... Jessica Boucher Motors 7 14-01-2002 19:36
