Go to Post Give me enough gearboxes and I'll move the world. - SenorZ [more]
Unread 23-06-2002, 23:18
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
circuit breaker
Posted by Josh at 1/20/2001 9:55 AM EST
Engineer on team #419, Rambots, from Wentworth Institute of Technology.
Is there any empty space in the circuit breaker? like how much of the inside of the circuit breaker is actually used for the internal components. could we drill holes (for weight perpouses and such...really) in it if we were careful not to hit or alter anything inside it?or is it completely impossible to modify it like that?
Josh
"you keep using that word, i do not think it means what you think it means."
#0047 (ChiefDelphi)
Impossible? Who knows...Allowed? Nope...
Posted by Nate Smith at 1/20/2001 12:06 PM EST
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
In Reply to: circuit breaker
Posted by Josh on 1/20/2001 9:55 AM EST:
Not a bad idea, but unfortunately, it's not allowed...rule C1:
The Operator Interface, Robot Controller, Servos, Speed Controllers, Relay Modules, Radio Modems, Batteries, Battery Charger, Power Supply, 9 pin cables, CIRCUIT BREAKERS, fuses, and joysticks may not be tampered with, modified, or adjusted in any way...
I know there have been a couple updates that slightly modified this rule, but none of the changes had anything to do with the breaker...sorry..
Nate
#0047 (ChiefDelphi)
Re: Impossible? Who knows...Allowed? Nope...
Posted by Josh at 1/20/2001 12:26 PM EST
In Reply to: Impossible? Who knows...Allowed? Nope...
Posted by Nate Smith on 1/20/2001 12:06 PM EST:
: Not a bad idea, but unfortunately, it's not allowed...rule C1:
: The Operator Interface, Robot Controller, Servos, Speed Controllers, Relay Modules, Radio Modems, Batteries, Battery Charger, Power Supply, 9 pin cables, CIRCUIT BREAKERS, fuses, and joysticks may not be tampered with, modified, or adjusted in any way...
: I know there have been a couple updates that slightly modified this rule, but none of the changes had anything to do with the breaker...sorry..
: Nate
thanks a bunch.
Josh
"DOWN WITH THE MAN!" -(can't post name due to politics).
[IMG] code is Off
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
120 A circuit breaker tbmantia Electrical 2 05-02-2003 12:30
Pump Problems... archiver 2001 2 23-06-2002 23:58
60 amp Circuit Breaker Info archiver 2001 1 23-06-2002 22:33
Circuit Breakers: Tripping Al Skierkiewicz Electrical 7 10-04-2002 12:40
