Go to Post Besides, you know hard it is to solder with gloves on? - Al Skierkiewicz [more]
Unread 24-06-2002, 02:55
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
optical sensor
Posted by joe frick at 03/27/2001 12:14 PM EST
Engineer on team #466, bartram braves, from john bartram high school and sheet metal workers local union 19.
could anyone help me with the optical sensor?
i want to use it as a limit switch how do i hook it up to digital imputs to control PWM 3 what i need is something that lets me start a match in a down position but prevent our robot from returning to this position during a match, so the switch would have to allow our robot to go up but not down. any help wou;ld be appreciated
#0047 (ChiefDelphi)
Re: optical sensor
Posted by Lloyd Burns at 03/27/2001 4:58 PM EST
Engineer on team #188, Woburn Robotics, from Woburn Collegiate and TorDistSchoolBrd, ScotiaBank. OntPwrGen, Enbridge.
In Reply to: optical sensor
Posted by joe frick on 03/27/2001 12:14 PM EST:
: could anyone help me with the optical sensor?
: i want to use it as a limit switch how do i hook it up to digital imputs to control PWM 3
' see the connection diagram on the case, and the listing of the pinouts in the Innovation First manual.
One of the wires goes to ground, one to the +5 V pin, and one (of the two outputs) to the signal pin. One of the outputs is closed normally, but opens when it detects reflection; the other output closes at the same time. Closed to ground = 1 in the program.
: what i need is something that lets me start a match in a down position but prevent our robot from returning to this position during a match, so the switch would have to allow our robot to go up but not down. any help wou;ld be appreciated
' if rc_sw# = 1 then PWM3 = 0 (or 254 depending on how you've wired the motor.) This could compress into
PWM3 = 127 + rc_sw# * 127 (if 254 is up, or use - to get to 0).
' you could implement another limit switch or a timer / counter to make sure the part rose far enough, if your sensor is positioned to sense only the start.
#0047 (ChiefDelphi)
Re: optical sensor
Posted by Travis Hoffman at 03/27/2001 10:18 PM EST
Engineer on team #48, Delphi E.L.I.T.E., from Warren G. Harding High School and Delphi Automotive Systems .
In Reply to: Re: optical sensor
Posted by Lloyd Burns on 03/27/2001 4:58 PM EST:
: : could anyone help me with the optical sensor?
: : i want to use it as a limit switch how do i hook it up to digital imputs to control PWM 3
: ' see the connection diagram on the case, and the listing of the pinouts in the Innovation First manual.
: One of the wires goes to ground, one to the +5 V pin,
The optical sensor runs on 12 VDC. Tap the power for the device from the 20A Robot Controller circuit breaker.
Travis
: : what i need is something that lets me start a match in a down position but prevent our robot from returning to this position during a match, so the switch would have to allow our robot to go up but not down. any help wou;ld be appreciated
: ' if rc_sw# = 1 then PWM3 = 0 (or 254 depending on how you've wired the motor.) This could compress into
: PWM3 = 127 + rc_sw# * 127 (if 254 is up, or use - to get to 0).
: ' you could implement another limit switch or a timer / counter to make sure the part rose far enough, if your sensor is positioned to sense only the start.
#0047 (ChiefDelphi)
Yer Right - 12 V :-(
Posted by Lloyd Burns at 03/28/2001 6:27 PM EST
Posted by Travis Hoffman on 03/27/2001 10:18 PM EST:
: The optical sensor runs on 12 VDC. Tap the power for the device from the 20A Robot Controller circuit breaker.
: Travis
[IMG] code is Off
optical sensor majormusic2005 Technical Discussion 1 29-01-2003 07:39
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
Find any optical sensor in catalogs? GreenDice Programming 1 13-01-2003 18:05
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
