Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Unread 21-07-2002, 18:43
Eugene Eugene is offline
#0321 (Lancers)
Eugene is on a distinguished road
Send a message via AIM to Eugene
Getting ready for the next season
Hi everybody!
I want to thank everyone for a great FIRST season.
In the mean time to improve on my engineering knowledge I took on a project that involves testing different configurations of a flywheel. To start this project I will need to find a suitable motor to spin the flywheel and a generator with a resistor block to simulate load. From there the calculations for the flywheel will be made (Size, mass etc…) and the different configurations tested. The problem is that there are so many companies offering motors and so few offering generators, that I got lost. I would appreciate any suggestions from you, the bright minds of FIRST.
For the power of a motor a figure of 1/3HP was thrown (Does any one by any chance have any idea on how to convert that into Watts?), since the power rating of the motor is the starting point I’m open to suggestions in this aspect. The motor should be around 12V DC, since this is one of the most common voltages. The generator should have a rating comparable that of the motor, so it would be able to effectively provide the load on the flywheel. A built in tachometer would be a nice feature to have.
If anybody has any suggestions to where I could find those materials I would really appreciate it. I will keep posting the progress of the project once I get it started.
Thanks a lot for your support!
Eugene
Unread 21-07-2002, 22:52
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
1 HP = 746 watts..... so 1/3 hp = 248.6667 watts.
Tom
Unread 22-07-2002, 10:24
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Suggestions
Here are some suggestions on where to get some of your needed stuff:
Flywheel - McMaster Carr has tons of metal wheels of different weights and sizes. If you don't want one to big (6" dia. and under), it looks like you can find one for under $30. Either go to McMaster Carr on the internet of find one of their handy catologs.
Generator - I'm not an expert in this area, for sure... but I'll provide another suggestion: I'm not sure about this, but I think that an automotive-type alternator may work for your needs. A typical car's alternator is probably too big for your use, but I assume that it provides the right type of output for what you want to do. Someone with more experience with smaller alternators may need to jump in here.
Tachometer - McMaster Carr also has a these, in a variety of styles.
Sorry I can't help more.
Andy B.
Unread 22-07-2002, 16:39
#0321 (Lancers)
I have noticed that some motors (Just plain motors, w/o any gear boxes and other mechanisms) seem to spin freely once un-powered while others seem
to stop. Or when spun by hand some continue rotating while others stop. It is very important for this experiment to get a motor that would not interfere with the rotation of the flywheel. I would appreciate if anyone could tell me how I could distinguish between two motor types.
Thanks
Eugene
Unread 23-07-2002, 19:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think it has something to do with the strength of the magnets in the motors.
Unread 23-07-2002, 23:06
Andy A. Andy A. is offline
Getting old
FRC #0095
Any motor will slow down after you remove power, all motors have some friction and resistence in them. To completly remove that influence, you'd need to some how use a clutch to disconnect the motor from the gearing. Or, even better, the flywheel from the gearing.
As for a generator... Why not just a D.C. motor? Put some resistors across the leads to simulate load. D.C. motors function just like generators in this way. This is probably cheaper then a generator.
One note, you should probably use a fuse or breaker in the resitor block... Other wise you might melt down some resistors and/or start a little fire.
-Andy A.
Unread 24-07-2002, 08:19
Matt Reiland's Avatar
'The' drive behind the drive
You can get cheap digital tachometers from tower hobbies also they are used to check prop speed on air planes but should work on your test stand also.
Unread 24-07-2002, 12:15
MBiddy's Avatar
MBiddy MBiddy is offline
Groovy!
#0862 (Lightning)
MBiddy is an unknown quantity at this point
Send a message via AIM to MBiddy
Anyone know where to get a decibel-ometer? To measure the volume of sound in decibels?
Unread 24-07-2002, 23:22
#0321 (Lancers)
Thanks Guys! I appreciate your support! I said the same thing to my mentor about the generator, but he said generators and motors are made differently. I guess he was probably thinking about an AC generator.
Eugene
Unread 25-07-2002, 11:25
You can get a sound meter at radio shack used for setting up Home theaters to a reference level, the analog meter is suggested and it is pretty inexpensive.
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
Highlights of the season... Alexander McGee General Forum 25 26-06-2003 03:13
Last post of the 2001 season... archiver 2001 0 24-06-2002 03:14
Who's ready for WPI3? Greg Perkins Off-Season Events 13 04-06-2002 18:23
