Go to Post I'm glad to be on the same team as smart people. - Andy Baker [more]
Unread 09-01-2002, 22:45
dense's Avatar
dense dense is offline
#0907 (Cybernetics Core)
dense will become famous soon enoughdense will become famous soon enough
We recieve 2 types of sensors in the kit right?
The optical sensors and the Yaw Rate sensors.
How are the Yaw Rate sensors used?
thx
-Shafi
Unread 09-01-2002, 23:02
zorro zorro is offline
#0292 (PantherTech)
zorro is an unknown quantity at this point
Send a message via AIM to zorro
The yaw rate sensor, commonly referred to as the gyro, detects changes in rotational velocity. It can be used to detect if your robot is tipping, how fast an arm is moving, etc. It is a cool sensor to use if you have a need for it (ie balancing a bridge). I don't see much need for it in this year's game. If you want more technical details, I'd be happy to supply them.
Unread 09-01-2002, 23:21
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Stability control?
We used the gyro last year for autobalancing on the bridge, but there doesn't seem to be such an obvious application this year.
Maybe it could used damp yaw motions and make a 'squirrly handling' robot easier to drive in a straight line. Has anyone tried such an application?
Team 1062, The Storm, 2003
Unread 09-01-2002, 23:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
The only use I could think of for the gyro for this years game was a little bit of a stretch for a gyro
I proposed that we set it to tilt the robot to one side, if we were in a situation that another robot was trying to pick us up, the gyro would tip us off of thier clutches.
I don't even know if a gyro could do this since I suck at anything electrical and am taking my intro to electrical class in college for the 4th time next semester
but It was the only thing I could think of as an application for the gyro
Unread 10-01-2002, 08:28
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
One of the most useful things to do with the yaw rate sensor in the kit is to keep your robot tracking in a straigth line.
You can generate a desired yaw rate, compare that to the actual yaw rate (from the yaw rate sensor) and give one side or the other more or less voltage in order to have the robot turn (or not turn) as desired.
It can make a really tricky machine behave well, especially 2 wheel drive systems.
Joe J.
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
